Garage Door Opener Mod. Done - with pics.
Just did this mod, for anyone interested you can purchase an on/off (not momentary) switch w/ rubber boot here
http://www.allelectronics.com/make-a...USH-OFF/1.html
http://www.allelectronics.com/make-a...R-PB-21/1.html
About $2 plus shipping
I did a similar mod except that my Genie GD opener was powered by a 12v battery so I just wired it up to an unused accessory wire on my FLHP:
https://www.hdforums.com/forum/touri...er-switch.html
They used a saddlebag unlock switch(?).
It was a very clean install.
I will try to find it for you.
It is in the DIY thread, Post #366.
He (jagerbomb) made three entries.
He did a great job with this installation.
https://www.hdforums.com/forum/4594153-post366.html
https://www.hdforums.com/forum/4594419-post367.html
https://www.hdforums.com/forum/4594433-post368.html
Originally Posted by jagerbomb
I wanted integrate my garage door opener on my bike so that it was easy to use and look factory installed. I started by looking for a momentary switch that would fit in the lower dash filler. I had 2 empty slots on my 2009 StreetGlide. I went to Doc's Harley Davidson in Kirkwood Missouri and Chris knew jsut what would work, a bag lock switch part# 71764-07. I ordered 1 for myself and another for a buddy. I started by taking out the ignition switch, using a 7/8" wrench to take off the the ignition support, and then removing the position plate. Took off the 2 side screws and the filler came right off. I took it to the workshop and removed the screws for the block off plates. I then took my new switch and cut the plug off. With a DVOM I determined the red and blue wires had continuity when the lock button was pressed. I tinned the wires and then took the cover off my garage door opener. With the DVOM I again determined which points on the circuit board had continuity when the door opener button was pushed. I then soldered the wires to those points. I then cut 2 grooves for the wires. The switch was installed in the bracket and screwed back in the filler. I then used velcro to attach the door opener to the filler panel checking that there was no interferance with the forks. I then put it all back together. Took me 20 minutes and it looks factory and woorks great.
Very nice, congrats, looks good
I have the HD Part# 71764-07 Switch wired into my Garage Remote, I did the install a few weeks ago. I have it Velcro'd under the switch panel, and it's working great too. Since I only have one garage door to open, I took the 2 outside wires and wired them together, so the Garage Door will work, if you push the lock or unlock button on the switch. I also installed the HD Independent Control Auxiliary Lamp Wiring Harness HD Part# 69200441 at the same time.
http://www.harley-davidson.com/gma/g...0&default=none
I didn't have to pull the Fairing, just the Ignition Lock and switch panel. They both took around a 1/2 hour to install.
Just did the LED Truck Lite 7 install too
Here are a few pics !!
