new rubber what do you call it
Old 11-11-2012, 10:37 PM
Bushy's Avatar
Bushy
Bushy is offline
Default new rubber what do you call it
hello.
the answer is out there I am sure... I seemed to have had the little rubber piece on the antenna removed somewhere along the way.... I have a 2012 limited and one of the rubber pieces that prevent you from losing an eye is missing....does anyone know what they are called and where do you get a replacement?
Old 11-12-2012, 12:16 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
I would imagine it's called a "tip" or "cap", Try Radio Shack.
Old 11-12-2012, 01:07 AM
DOMAPOI's Avatar
DOMAPOI
DOMAPOI is offline
Go to Home Depot, buy a can of Plasti Dip in what ever color you want your tip to be. Dip it several times until you get it to whatever thickness/diameter you want.
Old 11-12-2012, 01:36 AM
hockey8787's Avatar
hockey8787
hockey8787 is offline
vaccumm line plugs will work well
Old 11-12-2012, 08:39 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
jcb1975@yahoo.com is offline
I used black silicone caulk. Put a dab on the tip, let it cure for a few hours, then formed it into a ball. Still on there two years later.
It's always funny til someone loses an eye.
Old 11-12-2012, 10:10 AM
AnotherBlackSG's Avatar
AnotherBlackSG
AnotherBlackSG is offline
Get rid of the ugly whip and install a shorty or a hidden one in the fairing.
Old 11-12-2012, 11:58 AM
piasspj's Avatar
piasspj
piasspj is offline
I should climb up and take a look to see if mines still there.
I should remove it to get even for all those tall bastages that always put things on the top shelf.
Old 11-12-2012, 12:03 PM
07FLHT's Avatar
07FLHT
07FLHT is offline
"new rubber what do you call it"
When I need a new rubber, I call it "Round 2".
Old 11-12-2012, 01:40 PM
Bushy's Avatar
Bushy
Bushy is offline
these are the shorty stock antenna from HD ... look good
Old 11-12-2012, 01:59 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
Antenna Condom
Quick Reply: new rubber what do you call it
