Suspension Hand Pump issue...I need help !!
I have a 2000 Electra Classic. I bought a Harley hand pump yesterday because i'm riding with NO air and I have a wobble at high speeds.
I'm able to screw the pump to the stem and pump it to my desired 23psi with no issue on each side.
My problem is I seem to be losing ALL of my air as I unscrew the pump from the stem. I called the Harley dealership and they said to unscrew it faster
I tried that (knowing there was no way that it could be done that quicly) and of course the air still came out to Zero. I have no way to check existing pressure either. When I hold the pump to the stem to check the pressure it reads zero and oil comes out.
Am I using the pump incorrectly? There is a button on the model pump from hatley that I have if that helps.
Excuse my lack of knowledge with this, i'm learning.
I'm about to take a ride from ATL to Memphis in the morning and I need to get this take care of today !!
![Icon Gunhead](https://www.hdforums.com/forum/images/smilies/icon_gunhead.gif)
I can't recall which years have what, but yours either has one schrader valve (like a tire fill valve) for both rear shocks like my 2009 Street Glide, or you may have two valves. If you have two, I think one is for the rear suspension and the other is for the front.
Replacing the valve stems is easy and inexpensive. Go to the auto parts store and get a "Valve Core Tool". They are only a few dollars. Take the valve stem cap off and look closely at the Schrader valve. It had a stem that you can depress to let air out when the system holds pressure. Inside the stem barrel around the stem pin you should see two ears. Kind of hard to describe but it should make sense when you look at it. Slip the tool over the stem pin and onto the ears.
You may just have to tighten the valve cores (turn clockwise until they stop). Cores are cheap so I would probably just unscrew them and take them into the auto parts store, buy replacements, and screw the new ones in. If you are using the HD hand pump and the system still does not hold pressure, you have an air leak somewhere else, either from a line, fitting, or shock absorber.
