00'roadking 'NO SPARK'
HOWDY, here,s the scenareo,my bagger has [no spark] what Ive done so far is 1]checked fuses,2]looked for loose connections, and possible grounding issues,3] checked codes.[1-10 show clr]..4] unplugged the powercommander and plugged into ecm.5] took off tank to check the coil, with testing light [with ignition in on postion . im not lighting -up on any of the 3 prongs going into the coil.].sled was running .good, Stopped for a second [**** brake] .got on the road again gunned it a bit. to get up to speed and sled just died]..[no spark] .. IVE GOT THE COIL OFF TO TAKE IT TO THE HARLEY DEALER TO GET IT CHECKED TOMMOROW BUT WONT BE ABLE TO BE THERE TO ASK, WHAT NEXT IF NOT THE COIL. iM THINKING NEXT THING IS SENSOR,S [CRANK AND CAM] ..ANY IDEAS. ON WHAT I SHOULD DO NEXT.?
