Weak/no spark
Old Mar 18, 2017 | 07:02 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default Weak/no spark
The bike is a '94 FXSTC
I get mostly no spark but sometimes a weak one will show up.
The coil ohmed out good, new plug wires, tried a different ignition module (no change), the cam sensor is only 1.5 years old.
I get full voltage to the positive side of the coil.
The coil is original I think.
I hooked up a test light to the negative side of the battery, put the probe on the negative side of the coil and when I removed it I still got no spark at the plug.
Not sure what I'm missing.
Anybody got any ideas????
Old Mar 18, 2017 | 07:30 PM
daven9113's Avatar
daven9113
1) Coil might ohm out good, but is on its way out. 23 years, and it's tired. Swap it with a good one and test.
2) Plugs?
3) cam sensor? Solid state stuff can just go out, but you would not get intermittent spark. I would open up to see if it melted or maybe got wet, etc...
I suspect a bad coil.
Dave
Old Mar 18, 2017 | 07:38 PM
texashillcountry
Dirt don't hurt
2) Plugs?
Dave
I am gonna buy a new coil on Monday.
Even if it ain't the coil I can add one more spare part to my shelf.
Plugs are NGK iridium with about 1.5k miles on them.
Old Mar 19, 2017 | 07:40 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Weak or yellow spark is always a coil. Unless you have low voltage.
Old Mar 19, 2017 | 07:48 AM
Dr.Hess's Avatar
Dr.Hess
Your test light/remove on the coil negative won't tell you anything.
A coil swap would not be a bad idea. You could even test it with any automotive coil laying around. A coil is a coil at that point. And the only other thing left is the cam sensor, or the wires between it all.
Old Mar 19, 2017 | 08:54 AM
1997bagger's Avatar
1997bagger
Have a fluxcompacitor coil on the White Bike, got hit pushing a comression release one day, you might check into this coil
Old Mar 19, 2017 | 09:24 AM
Beemervet's Avatar
Beemervet
Dang! Now I know what to ask for fer my burfday.
Old Mar 19, 2017 | 10:08 AM
WP50's Avatar
WP50
Would what he is doing with the test light be kinda like opening a set of points on an older car? I remember getting bit by a coil some back in the day.
Maybe the newer stuff don't work that way I feel old now
WP
Old Mar 19, 2017 | 11:11 AM
texashillcountry
Dirt don't hurt
I just put a new OEM one in a year and a half ago.
Don't they normally last longer than that????
Old Mar 19, 2017 | 12:26 PM
Dr.Hess's Avatar
Dr.Hess
Anything can fail at any time, so even if it is a year old, it is still suspect.
If you think about the circuit, WP, when you turn the ignition on, the coil should be charging itself because the coil negative should be grounded by the ignition module (or points.) The coil is fired by opening the circuit (ground), mking the coil collapse and inducing a current in the secondary circuit, the high voltage side of the coil. A test light has a bulb in series between the pointy end and the alligator clip. Not much current will flow through the bulb. The coil is charged by a bunch of current flowing through it. Plus, the coil is already grounded at the negative side. So, adding an additional high resistance circuit between ground and the coil negative, then removing it will do nothing at all to the coil if it is still in the main circuit, and damn little if you pulled the coil negative side first.
