Synthetic Oil Not Recommended by Factory in Primary
Old 08-15-2012, 09:33 AM
Dew Me's Avatar
Dew Me
Dew Me is offline
Ya know...it's real easy to make fun of the idea of putting engine oil into a primary, but I don't think any of you are lubricant experts. There are lots of things out there that take on new/more uses. For example, a majority of 5 SPD MANUAL transmissions in the 80's used ATF. Who thought THAT made sense!?
  #62
Old 08-15-2012, 09:43 AM
Yukon42's Avatar
Yukon42
Yukon42 is offline
Been using syn 3 HD oil in the primary and trans since new in my 08 RG. With 61k miles not a hint of a problem. No problems with wheel bearings either; still running the originals. Very entertaining thread though......
  #63
Old 08-15-2012, 10:09 AM
DDuess's Avatar
DDuess
DDuess is offline
Originally Posted by cochon
I'm sorry. I don't mean to call you out or be rude, but, what does a reference to automobile automatic transmission fluid have to do with the OP's question? Are you even remotely suggesting that Mobil 1 ATF has any place in a Harley? If so, please explain your thoughts.
It would seem that a lube designed for high temps, clutch packs, gears and chains (automotive automatic trans components), requiring virtually no change interval in service, would work in a primary. Works in mine, the clutch is just fine, and not as sticky in the morning, particularly cold mornings.
  #64
Old 08-15-2012, 10:15 AM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
That's been my experience too. Formula+ seemed to work equally as well on the sticky clutch plates though, just more $$.
  #65
skratch's Avatar
skratch
skratch is offline
Received 4,193 Likes on 2,457 Posts
and here we have it folks. use the hd syn3 engine oil and your wheel bearings will last longer
  #66
Old 08-15-2012, 10:28 AM
beary's Avatar
beary
beary is offline
Yes, I've tried just about all oils in the primary including ATF and nothing is as good as Formula+ for me. I don't use Harley oil in the tranny or crankcase, so it's not that I'm a fan of the Harley brand, Formula+ just has the best feel with the clutch for me.
Beary
  #67
Old 08-15-2012, 10:53 AM
shrice51's Avatar
shrice51
shrice51 is offline
Been using AMSOIL ATF in my '80 FXEF primary for over a dozen years and AMSOIL synthetic ATF in my '03 FLHTCI primary for two years. HB 125 hydraulic chain tensioner in both, and both setups work very well. Smooth solid shifts under heavy loads, no clutch plate slippage, and clear fluid after 3k miles on the newer '03.
  #68
Old 08-15-2012, 11:10 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by Dew Me
Last bottle I read said full synthetic and it surprised me.
I'm putting Redline Primary in next time. I don't see why SYN 3 is a problem though.
I agree DM
  #69
Old 08-15-2012, 11:29 AM
Mark98012's Avatar
Mark98012
Mark98012 is offline
When I asked a couple of months ago (when I did my '11 Limited) they suggested HD +3 in primary and trans, I use Amsoil in the motor.
  #70
Old 08-15-2012, 11:39 AM
cochon's Avatar
cochon
cochon is offline
Interesting. I've never heard of using ATF in the primary but I guess that it's a good day if you can learn something new! I may try it sometime. Thank You.
Quick Reply: Synthetic Oil Not Recommended by Factory in Primary
