Cylinder Base Oil Leak
I have a 13' Street Glide with 560 miles on it and today I noticed oil leaking from both cylinders at the base of the cylinder. It's a small leak at this point and I am concerned that if I continue to ride it, it will get worse. I have not ridden it hard since it's still breaking in.
I called the dealership and made an appointment to bring it in to get it checked out. Has anybody heard of this happening on a twin cam? i know it was an issue with Evo's.
For the most part, probably just a bit too much lube was used on initial assembly and the oil is weeping out between the jugs and base.
If the base just appears to be slightly wet, I would just watch it and ride it.
It's most likely just leftover oil from assembly, a few others have found the same thing in the first 1K. Let the dealer make note of it & clean the area thoroughly & I'm betting it won't come back. The EVOs used a base gasket while the TCs use an O-ring, I pretty sure you're worried about nothing.
Been numerous post of it coming out under the head bolts. Enough to spread out over the flat black paint. Looks white looking then. In most cases was assembly lube. Goes away after couple cleanups and heat cycles. Let us know what you find out. Take a few pictures and post before you carry it in for future reference for everyone.
