cam tensioner issue
Old 11-14-2012, 12:44 AM
eberg's Avatar
eberg
eberg is offline
Default cam tensioner issue
Anyone have had issues as described in this article, what have you done about it?
http://blog.jpcycles.com/2012/11/i-love-harley-davidson-but-you-must-know-this/?utm_source=SilverpopMailing&utm_medium=email&utm_ campaign=newsletter&utm_content=2012-November-Biker-Buzz-nongc-minus-gmail&utm_term=twin_cam_defect&spMailingID=4054028 6&spUserID=MzQ3NDAyNDU1MjMS1&spJobID=167269262&spR eportId=MTY3MjY5MjYyS0
Old 11-14-2012, 01:26 AM
2AMGuy's Avatar
2AMGuy
2AMGuy is offline
Received 2,505 Likes on 1,609 Posts
The early T/C 88's definitely have an inferior design on their cam chain tensioners.
Some folks claim using synthetic oil increases the life of the tensioners but regardless of that, after 20,000 or so miles the tensioners should at least be checked for wear.
Failing to check and/or replace the tensioners can possibly lead to engine failure.
In addition to simply replacing the stock tensioners the options are either installing a gear drive or a hydraulic cam tensioner kit.
Around here, the stock replacement cost is between $350-$400 bucks.
I had my 2000 T/C upgraded this past spring with the S/E Hydraulic kit for about a grand and I think the gear drive is a little cheaper.
Some people complain about a little more noise with the gear drive set-up but both it and the hydraulic kit will last much longer than the OEM stuff.
Old 11-14-2012, 03:20 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,365 Likes on 2,619 Posts
Old 11-14-2012, 04:26 AM
TexasFatboy's Avatar
TexasFatboy
TexasFatboy is offline
Definitely an issue.
It’s a gamble really.
My 2004 FatBoy showed normal wear at 50K when I sold it. Ran SYN3 from the day I got it. But honestly, tensioner failure was always in the back of my mind. Guess I got lucky.
Old 11-14-2012, 06:18 AM
RK Joy's Avatar
RK Joy
RK Joy is offline
I ran a TC88b for 10 years with Syn3 and never had a hiccup.
Old 11-14-2012, 06:52 AM
hambone51's Avatar
hambone51
hambone51 is offline
Had mine checked by dealer at 21k and inner tensioner was completly worn out. Went to gear drive and had new cams at the same time. Very little gear wine with this set up. Have to really pay attention to hear it. Just had Blacsktone oil analysis and got excellent report after 2 years with this set up.
Old 11-14-2012, 07:13 AM
fwb35's Avatar
fwb35
fwb35 is offline
Having a 99 I bought this past June I did much research, the problem is different companies made the chains that the tensioners push on, some are rougher then others, also the springs were found to have more tension on them then others, thats why you have different amounts of wear, oil is not going to make much of a difference. Some will wear out in less then 20k and some will last over 50k, is a crap shoot. Mine were replaced by the indy I bought my bike from, they were shot a 38k, I have since driven it about 10k and just checked them, I do not like how they look and are wearing, I am taking the bike in Sat for the SE upgrade kit to include new cams, whole job is about $1,500 out the door. I to do not want to keep wondering when one will let go and have some peace of mind, is a design failure and should have been taken care of by the motor company, they are basically saying we admit there is a problem by making a upgrade kit and are telling us we have to pay for it or suffer the consequences. If you keep the old style in there make sure you check them every 10k miles in my opinion.
Old 11-14-2012, 08:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
There are dozens of threads in here about those tensioners. You have several choices: check at regular intervals and replace the worn stock components as required; upgrade with the SE kit that includes an improved design (my choice); or install a gear drive cam-set (expensive and not necessary IMHO).
Old 11-14-2012, 08:29 AM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
You mean kind of like replacing a timing chain or belt in a cage? Just part of owning a motor. I know mine is overdue.
Old 11-14-2012, 08:53 AM
kmayHD's Avatar
kmayHD
kmayHD is offline
Heres mine a few months ago, bike has 20k miles. Ive had the bike 2 years, always run regular 20w50 dinosaur oil. Was a sherrif/supervisors bike, had an easy service life. Theres not even a wear groove in the tensioners, really took a load off my mind. I was constantly thinkin about these damn things while riding, had to get in there and see for myself!
Quick Reply: cam tensioner issue
