Hayden Primary Chain Tensioner - Pictures
Old 02-24-2013, 01:47 PM
so60's Avatar
so60
so60 is offline
Thumbs up
Originally Posted by fathog
So if I understand you correctly you ended up with a 1/4" when completed? Any up and down left in the chain? Does you chain seem to have the same tension on it as with your prior set up?
Yes, I ended up with 1/4 inch. The chain is tight but it was pretty tight before. After installing I can push down on the top of the chain (in the middle area between comp and clutch) and get very little movement. I could put my thumb under the chain and my index finger on top of the inner case and squeeze upward and get the chain to pull "up" a half inch or so. Pushing down on the top of the chain doesn't give much deflection though. It feels a little tighter than the original setup, but my original was still pretty tight. Hope I described this where you can understand it. It "sounds" good when running though. I am not getting any "whirling" sounds, but my hearing is not as good as it once was... LOL
  #422
Old 03-09-2013, 05:59 PM
fishbust's Avatar
fishbust
fishbust is offline
Just finally got around to getting my bike back together and riding for an hour.
Last bike I put an M6 on I built the bike with it, along with many other upgrades, so I never knew the difference.
After riding my 2000 cop glide for 2 years and just doing this job, night and day difference shifting and finding neutral is no longer an issue when bike is not moving.
Every bike should be built with these spring loaded shoes in the first place. Set it and forget it.
  #423
Old 03-09-2013, 06:40 PM
MikeTD3's Avatar
MikeTD3
MikeTD3 is offline
I put my SE Comp and Hayden M6 on today, it was right at 3/8" with no shims...so I guess I'm good to go.
  #424
Old 03-09-2013, 07:32 PM
NECaveman's Avatar
NECaveman
NECaveman is offline
I see HD just came out with a new SE primary chain adjuster. This one is a manual adjuster with the adjustment bolt on the rear end. The primary cover has to be removed to inspect or adjust the unit. I don't think this unit is a improvement over the Hayden.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
  #425
Old 04-05-2013, 03:30 PM
NiteOwl's Avatar
NiteOwl
NiteOwl is offline
08 SG 110ci 35k miles, ride 1-up mostly but do take 2-up trips a couple times a year loaded with gear.
Just replaced my compensator to the SE version and my clutch pack. (This machine suffered from the embarrassing hot-restart problem) My stock H-D chain tensioner shows wear on the shoe, not a show stopper by my reckoning. . . I was not happy to find that my fwd bolt that attaches the tensioner was actually bent, when I removed it. Was it a factory mistake or something, I do not know, I do know it has never been out, perhaps the chain tensioner was over tight at one point, I don't know, the tensioner was ok when I pulled it. Anyway, today I decided I would order the Hayden unit and install it along with a replacement bolt. Thank you to the OP and some of the discussions following in this thread.
  #426
Old 04-05-2013, 04:16 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Nightowl tell me about this hot-start problem at the start of your post, Im over this forum and Ive not heard about this problem.
  #427
Old 04-05-2013, 04:34 PM
NiteOwl's Avatar
NiteOwl
NiteOwl is offline
ok, not to hijack this thread here is the skinny. . . One of the best threads can be found here https://www.hdforums.com/forum/touri...it-w-pics.html Basically, many have found one problem, when the bike gets hot and you shut down and attempt to restart shortly after, it sounds like a bucket of bolts and often results in a failed start. I have experienced this many times. Also bike performs poorly in low speed operation, shuddering etc. It comes down to the engine compensator being to "light" (Harley recognized it unofficially and all 2011" I think" models and up have the improved unit installed from factory). Lots of good discussion on the other thread.
  #428
Old 04-05-2013, 05:05 PM
GaugeMods's Avatar
GaugeMods
GaugeMods is offline
Former Sponsor
Well I just ordered mine from M&M cycles along with the Jims Transmision rebuild kit. ouch
  #429
Old 04-05-2013, 06:00 PM
kdfcogwheel's Avatar
kdfcogwheel
kdfcogwheel is offline
I recently (last week) replaced the primary chain tensioner with the Hayden M6. So far I have 127 miles on it. One thing that I really want to comment on is from a cold start, first of the morning, when shifting to 1st from neutral there is NO clunk! Just a click. No lurching, shaking, shuttering - nothing. After warm-up and I restart going from neutral to 1st - nothing. NOT even a click. Wow!! Unbelievable. I can't believe my ears. I have read here that most have not noticed any difference, but I sure have. I was at the dealer today getting a new rear tire, and was talking to a guy with a 2011 FLHTK. He started his after it sat for while in the parking lot, with everything still stock on his machine - it went CLUNK when dropped into 1st. I am glad I made the switch.
  #430
Old 04-05-2013, 06:19 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,551 Likes on 3,058 Posts
Somebody needs to explain to me how my "too light" stock 2000 original compensator is still in my primary 13 years and 125,000 miles since new then.(?)
Yeah I've got the Hayden, but this "clink clank grind" on hot starts is a 2007 and later phenomena ( 96" matched to a six speed tranny and later.) I believe the problem lies in that, and all these "improvements" are simply "patching" symptoms, not fixing the problem.
Quick Reply: Hayden Primary Chain Tensioner - Pictures
