Mirai Lithium Battery
Has anyone heard of or use Mirai Lithium battery? Was told by rep I can use Battery Tender as a trickle charger. I thought it has to use a Lithium battery tender. BTW, saw it at the Progressive International Motorcycle show in town.
This thread is specific to Marai Lithium battery. I've gone through threads about pros and cons, low ambiance temp affecting Lithium batteries. As well as Lithium vs AGM, why change, etc, etc.
TIA
TIA
Received 3,940 Likes
The Mirai is a lithium iron phosphate battery and should not need a trickle charger...but if for some reason it does, it needs a lithium specific charger.
You can also jump it off of any 12 volt battery, just make sure the vehicle is not running.
Received 2,524 Likes
Lithium Ion is what Boeing was/is using...it has a heat/fire problem.
Lithium Iron or Lithium Phosphate batteries are different, they do not have a heat/fire issue like the Ion batteries. They are also more expensive...which is why Boeing did not use them.
