Cam Install question, won't fire
Just finished cam, lifter, and pushrod install on my 09 streetglide. All are products from Fuel Moto. I would call them, but being a weekend, I thought I would ask here first.
Turns over after install but will not fire. Am wondering if this is a timing issue? On assembly, I set the two sprocket dots in line. Cam sprocket at 6 and crank at 12. Should both be at 12?
Both dots on the cams are in line directly across from eachother.
Advice or suggestions are welcomed.
Just go backwards on Your installation and check everything You touched or got close to. Hope You find it quickly. ndfrspd
