HF table lift and wheel removal
There was a recent informative post about the HF table lift, use of chocks, tie-downs, and side extensions, that I didn't want to hi-jack with this question. A few months ago I got the HF table lift but have not used it. 2 back surgeries and trying to recover, but that's a different posting. Before I got "grounded, I purchases 2 Michelin Commander II that are in the garage waiting to be installed. I still need to ride off about 1K miles, but that will work out fine since I will have to take short rides till I get my back and legs up to par.
Now the question. I also purchased a small HF scissors jack tho raise one end or the other of the bike. To remove the rear wheel is pretty straight forward, ride it on the lift, into the wheel chock, run some straps in the front, put the scissors just under the rear of the frame and then I have clearance, remove the lift panel and then remove the rear wheel.
How is it recommended to remove the front wheel while on the lift. Is there a convenient way to have the bike on the lift and remove both wheels. I also have a jack that I suppose I could put under the bike while it's on the lift to raise the front and rear together.
Looking for suggestions, thanks.
I am going to pull the wheels and have the local dealer install my tires and it would be helpful to make just 1 trip.
Secure this bike with the front wheel in the vise, strapped down as normal. Jack up the rear, then support the frame on blocks (wood - such as 4x4's or a 6x6 and a 4x4, or whatever works - just make sure it's stable). Then, loosen your straps & jack up the front. If your jack locks, lock it. If not, secure the bike on blocks & tighten straps down again. Then remove wheel vise for access to the front wheel. Nothing whatsoever unsafe about doing this. When tied down on blocks the bike is very secure.
