Best and Worst Air Intakes
#41
Hmmmm... doesn't look like they offer a kit for late model touring, or just the element alone. Could have missed it though... the website is being its typical slow-loading self.
#42
Do a google image search for 29442-99E. The 2 pics you see with a hand holding them are mine. It is only available as an air filter. Its not in a kit.
#43
Received 3,941 Likes
I bought the DK Customs kit with brass breather bolts and it blows oil all over my bike. Then bought their external breather element with the 2 houses that hang down into a separate breather and same problem oil all over the bike. Now i'm out almost 200 dollars combined for an air filter element I used less than a week. Unhappy to say the least. And NO it's not overfull only 3and 1/2 qts. of oil in motor 2009 street glide, it's not over filled at all.
Not sure what you mean by 3 1/2 quarts of oil not being over filled. Please take a look at this link, which has info from Harley on how much oil and what weight oil to run.
https://www.hdforums.com/forum/oil-r...oil-level.html
Here is another good link on oil being on the side of the bike, and the different reasons for it.
https://www.hdforums.com/forum/oil-r...f-my-bike.html
I believe if you will read thru and follow HD specs in the above two links you will end up very happy with the A/C you have. If you are not, please contact us at the number or email below. Happy Customers are our #1 Priority.
Regardless, he above info is important regardless what A/C you are running.
#44
I had the SE Heavy Breather when I did my Stage 1 upgrade to my 2012 FXDWG when I purchased the bike. 3500mi later.... I just did the SE Stage IV Kit and wanted to get back to the stock look so I did the Stage 1 Air Kit , Works great. The only thing getting use to was with the 58mm throttle body sticks out farther ,hitting my leg so I had to adjust how I place my foot on the footpeg. Its all GOOD , You GOTTA PAY TO PLAY !
#45
I had the Big Sucker and liked it a lot but even with the short element I had to sell it to put speakers in my lower fairings.
I went to the SE Ventilator but felt that it was giving off more heat. Maybe it was the way it directed air around the engine or maybe it was acting as a heat sink to the engine... in either case, I didn't like it and sold that.
I now have FuelMoto's setup and like it as much as my old Big Sucker.
#49
