HELP PLEASE: Got my oil pressure reading today.....
I've posted previously about my Road King's oil pressure light flickering.
Today I finally got to attach a pressure gauge and got the readings - below.
Here is my bike's specs: 2000 RKC with 47K and stock cams and stage one. I've got a Dobeck TFI.
There is no knocking or tap-tap-tap and the idle is where it should be.
The readingsoil at full level - Amsoil 20/50)
At start:
Idle - 38
Cold 2000 RPM - 40
Cold 2500 RPM - 45
Operating temp (oil temp 185)
Idle - 20
2000 RPM - 40
2500 RPM - 40
3000 RPM - 40
Is it strange that the pressure when warm does not go above 40 psi?
If you can tell me if the bike sounds normal or not that would be great - THANKS!
At start:
Idle - 38
Cold 2000 RPM - 40
Cold 2500 RPM - 45
Idle - 20
2000 RPM - 40
2500 RPM - 40
3000 RPM - 40
sound like pretty good numbers to me.
As the oil warms up it gets thinner, so your pressure will drop at idle.
It's not unusual to see warm idle pressure at 10 pounds, and sometimes less.
I'm sure someone with more knowledge than me will come on with a better way to explain.
thanks
The 2011 Touring Service Manual indicates the oil pump has a pressure relief. My manual in the engine oil flow section of chapter 3 says pressure relief is 35psi.
EDIT to add; Normal pressure at 2000 rpm is 30-38. Maximum pressure 50 psi
