Well, I've just ridden mine since I put the new gauge on and cold I'm showing 40 lbs at idle. Once it has warmed up, I'm showing 10 lbs at idle and around 30-35 at a 2500 rpm cruise. Keep in mind that it is 45-55 degrees here which may make a difference in how warm my engine is getting. Also, I have the SE pump and cam plate installed. Your results may vary.
I'm getting around 40psi when I first start it also, after warm up and I'm idling I'm getting around 10 to 12 psi and around 30 psi cruising....
