Removing rear bumper from FLHR
So, I was looking at the rear fender of my RK standard this weekend. With having fish tails, I don't really need the rubber bumper... Thinking about what I could do..
1. I could just remove the entire thing, bumper and rails. Might look too "naked" lol
2. I could see if I can just take out the bumper part and leave the existing rails. I cant decide if that would look right
3. Or, remove the entire thing and go with the RK classic type of chrome rails....
Anyone out there tried #1 and/or #2. How did it look, have any pics? Any other things that ya'll have tried?
Thanks!
Thanks!
How much work is it to swap the TL and signals and to add the SG fascia at the base of the fender? Also is the fascia lit? Thanks.
The tail lights are pretty much a bolt on swap. The fascia can be bonded on with double sided tape on bolted on like factory. Three holes on each side of the fender. Do a search on "Street Glide fascia install". There is a lot of detailed info on the forum about the installation.
The tri-bar light does work. You can use the run only light or the run/brake light. I used the run/brake light.
