Harley batwing mini apes?
Even with 10" mini-apes you may have to change the clutch cable, I went with a 4" over clutch cable with 10" Paul Yaffe Bagger Apes, you can use the stock brake line if re-routed. You will have to change the brake line and cables if you go with 12" bars.
You will not be able to use your stock fairing mount mirrors with 10" bars, might possibly be able to with 12" mini-apes.
If your bike is throttle by wire you will have to extend the throttle twist grip harness that is inside the bars, they make plug-n-play extentions, Eastern Performance has them.
You might possibly have to extend your switch harness for Turn, Horn, Starting with 12" bars, you will not have to with 10" bars.
Hope this helps!
Hope this helps!
Many people have put the 10" mini apes on their street glide without having to extend any wires or cables. Most likely have to do some minor re-routing of the wires and cables inside the fairing though. Some will extend the clutch cable a little bit just to have a little breathing room. I personally put the 10" LA Choppers twin peaks on my 2011 SG and did not extend anything, just rerouted the wires and cables.
You will not be able to use your stock fairing mount mirrors with 10" bars.
