2014 Hydraulic Clutch, Frame, and Steering Head changes
Can't help but ask, what are they thinking? There aren't many side car users out there, but now there CAN'T be any on the new frames. I suspect some after market outfit will engineer around this one.
Hydraulic clutch? Kinda neutral on that one, though I think eventual maintenance on a master cylinder and slave cylinder will be more expensive than cable replacement.
Steering head changes: Eliminate a nickle zerk (perhaps $1 at retail) in favor of front end disassembly every 25,000 miles, yeah, great idea. Now, where did I leave my drill?
I had a Yamaha with a hydraulic clutch. It had a nice feel and was low maintenance. Hopefully HD's will be as good.
I would imagine a lot of folks will be installing zerks before it's over. A tear down at 25,000 is ridiculous. You should see the steering head adjustment procedure, it's totally changed as well.
They have engineered into the 2014 changes plenty of shop time (at $90/hour) for the new owners that don't do their own work.
Received 70,440 Likes
Supposed to be a heavier clutch spring, and they wanted to keep the clutch feel the same. I don't think the RK comes with the HO motor, so that may be the reason why.
My 10 SESG has the hydraulic clutch. It is the first bike I have had that has one. I like it, has a consistent feel and works well.
