Trip review of 2014 Ultra Limited
#102
#103
I kind of have to agree with eshaw301 & his thoughts on the new limited. I took 3 demo rides in the last 10 days on a limited & the things that were most noticeable to me were the linked brakes are very nice but if you use the front & rears together on the none linked Brembo equipped baggers the result is identical. The vent does reduce buffeting considerably when it's open ,but the stock shield is also lower than the older bikes so you get more air hitting you especially if you're tall. I felt a modest increase in power over my stock 09 ultra but nothing like the guy who started the thread is stating. The audio system sounded the same as my 09 but to be fair I usually play cd's and on the 14 it was fm stations. Handling felt the same as my 09. My stock tires have 16,000 miles on them so of course the new limited leaned over & turned easier compared to my flattened out & scalloped tires. Sometimes you tend to be so charged up about your new purchase that you can't help but exaggerate a bit. I also felt some heat on the right side, similar to my 09. Read the report on ride apart.com. Under reviews. And having said all that I am sure I will get a 14 or 15 but I really don't think they are as much of a difference overall from the 09 thru the 13' s as this thread implies. I also rode a 14 cvo and that bike pulls like an 1800 gold wing. But it's nice to see someone so enthused about his new purchase. Great review & pics. Thanks for taking the time.
#104
Thanks for a great review. I only have 543 miles on my new limited and so far I agree with everything you said. I use the CB & the only thing I don't like about it is that they moved the PTT switch on the right side. Not a good idea in my opinion. I also use GPS, but make my own routes in base camp. Now I have to use 9 waypoints, via points or whatever HD wants to call them. I'm taking a 23000 mile trip next month so I'll see if the GPS will do what I want it to do.
#106
I did change it over, yes. I had just put the air wing on my 09 a month ago, so when I swapped bikes, I swapped the racks as I like the look of the air wing, even though the stock one is a bit larger. In case you guys didn't know, the air wing is a direct swap for the stock. Same bolt hole pattern.
#109
Had to re register to post this.
I traded my 2010 Limited for a 2014 for 2 reasons.
The promise of a slightly cooler ride and I like the new Daytona Blue Pearl.
After 1000 miles I have a small aggravation with the radio, it won't skip forward on an iPod or USB stick song list.
The handlebars on the previous bike were a nightmare after 4 different tries, Something on the 14 is slightly different, seat to bar ergonomics maybe. I may still change them, but so far I am OK.
Power is better, legs are cooler. So that worked out.
Handling is much better, when it was brand new I was just barely allowed to ride any at all (Post op gall bladder explosion) so I was very gentle and even then noticed that it seemed less "upsettable"
As I have gotten myself back up to speed I feel that the handling is indeed better.
Off camber curves are fine, as are fast sweepers. It does indeed handle much better, which I attribute to the stiffer front end.
The worst place I routinely ride is the transition from the road into my neighborhood. There is a drop, a short flat, and a rise, all in a few feet and that has been caution inducing on my 2010, and my previous Springer. It is now drama free.
Overall, I'm pretty tickled with it.
#110
1500 miles I guess I am a slow learner
still doing it https://www.hdforums.com/forum/image...s/icon_doh.gif
