Platinum Air Ride Suspension
Every bike I've ever owned in the last 12-15 years I've had air ride suspension from Hi-Low air ride to Arnott to Legend, now that I have the '14 Street Glide Special I would like to install these new Platinum air ride systems that have air and rebound selections so no pogo effect as you can have the top of the shocks solid as a rock but the bottom portion with air so adjustment is simply remove all air to "slam" the ride if you like but add in air for the rebound and no bottoming out, no pogo affect, regular shock effect even lowered to bottom. At least that's how I read it. Anyone using this Platinum air ride on their touring bike? What's your opinion of them? Do you get pogo effect at all, do you ride slammed? How is your ride slammed? Based on the experience of HDForums members I will make the purchase so hoping for good reviews. Thanks much.
I went from the DIY kit to just swapping the shocks to Platinum's on a 2013 RG custom. The best by far, but not cheap. I run a dual air gauge on this setup. It it pretty cool. As you add just air to raise the bike, it basically ranges from 70-80 psi low to high ride height. I don't have any control of the rebound section, but have manually added and removed air in this section, as long as you have 5-10 psi on the top section, it rides nice, no pogo. I have thought about controlling the rebound so I can ride low and comfortable, but honestly, topped out at 13" with a 1" lowering block isn't super high at all and feels really nice on my spine vs anything else. Hope my experience helps at all... BTW, Platinum Air doesn't do anything with actual PSI gauges so it's foreign if you call and ask.
Get a shotgun shock. It works the same but is engineered much better. Had Platinum on my softail and it was garbage. Too many connections and constantly leaking. Platinum has 2 connections on each shock where as Shotgun only has one connection per shock but they are both ride height and rebound adjustable. Call JD 323 35- 4914. Tell him HogPro sent you know. He'll take good care of you.
Ok... DO NOT GET THESE SHOCKS!!! They are terrible the rebound adjustment is terrible and the overall ride sucks so bad... I had them on my old street glide and I had to send them back twice because I needed them to be adjusted because I thought they were broken...
They go down very slow and shaky, they almost bounce down... they go up the same way... they are not a smooth up and down...
The overall ride was not comfortable at all...
If I was to do it all over again I would have spent 200 more and bought the shotgun bagger shock...
just my 2 cents.
Worst air ride on the planet and customer service is a joke...
just my 2 cents.
just my 2 cents.
just my 2 cents.
Giuseppe
