14 SG 12.5 ape install with PICS!!!
#121
#123
Need some help....I've installed new bars, using the TBW assembly with the green plug intact...all went well with install, upon putting it back together I have no throttle, check engine and cruise lights are on, everything else works, I tore it back apart, the connector was still attached, but I removed it anyway and soldered all the connections, carefully attaching yellow and black to their corresponding colors,reran the wires through the bars...same issue, no throttle...when I check for codes it says "diagnostic service not available" and no codes are recorded...I was going to buy a new twist grip assembly, but wanted to see if anyone had some suggestions before I do...could this be an issue with the ECM? freaking bike is brand new less than 1k on the clock!
#124
Did you ever find out what the issue was?
