SE 204 cams
Old 11-15-2013, 09:58 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
Default SE 204 cams
I have SE 204 cams in my TC96 2010 Ultra and was thinking about installing a 103 big bore kit. what's the highest compression I should go with the 204 cams and still have it drivable in the summer without pinging issues?
Old 11-15-2013, 11:10 PM
equandt's Avatar
equandt
equandt is offline
Keep it under 10:1 and you should be fine. Use the HD cast flat top pistons and a standard Harley head gasket (0.045" thick) and you'll be in good shape. I think this puts you at a static compression ration of around 9.7:1.
I would recommend putting in some manual compression releases if you don't have them already. By brother has this exact same set up in his 07 Street Bob and has some hot start issues. He's putting in compression releases this winter.
He doesn't have any pinging issues. It's a nice running set up.
Good luck. It's a nice, proven build.
Old 11-15-2013, 11:16 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
You can go to 10.5:1 if you back the timing off in cruise area from 2750 to 3500 to no more than 38 degrees and richen it up in that area also about 5%. The stock timing is way to high for any cam with over 10 to 1 in that area.
Old 11-16-2013, 10:32 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I would just do the SE cast 10-1 pistons and a .030 gasket. 10/10.2 is fine with 204s. 10.5 is pushing it but can work with proper tune. Of course, 10.5 and some more cam is always better... especially with headwork.
Old 11-16-2013, 12:14 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
Thanks for the feed back. The mechanic suggested setting the compression at 10:1 so that is what I will be going with. I like the 204's but if I were to change cams what would be a good cam to go with in a 103 with 10:1 compression?
Old 11-16-2013, 12:30 PM
0ldhippie's Avatar
0ldhippie
I'm running Andrews 54s at 10-1 without headwork with good results but 57s would be my pick now without headwork. Woods 555s/S&S 570 are a good ones too but like 54s they would really like headwork too.
Old 11-16-2013, 12:47 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
I was just reading about the 57H's do they like 10-1 compression?
Old 11-16-2013, 03:45 PM
0ldhippie's Avatar
0ldhippie
I think they'll love it.
Old 11-16-2013, 04:03 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
10:1 will be just fine.
Old 11-16-2013, 04:06 PM
Dozer40's Avatar
Dozer40
Dozer40 is offline
I went with 10:1 Pistons, .030 Cometic gaskets, Woods 555's with head work. No ping ever with just a few V tune runs. I'm pleased.
Quick Reply: SE 204 cams
