How long do you warm up the bike?
So I was reading an article the other day about making sure to give the bike enough time to warm up because it has a warm up time similar to a choke on a carbureated bike. I live one mile from work and the speed limit is 15 then 25 all the way there and the bike acts up when cold. I started making sure to let it run for two minutes and not allowing the EITMS to kick in and it seems to run smoother. The idle can be a little bouncy when cold too. So anyone else have similar problems? How long do you let her warm up before riding away? Oh this is a 2014 SG. Thanks guys.
Generally at home it's as long as it takes to get my stuff out of the garage, gear on, close garage. Bike is at normal idle by then and I take it easy for a mile or two to get the gear train warmed up. When I'm not at home similarly as long as it takes to casually gear up and then I usually sit and get the tunes flowing and it's usually at normal idle by then.
I start the bike, push it out of the garage (backwards), close the garage door and pull up to my locked fence. I open the fence gate door and pull the bike out to the alley. After closing the fence gate I ride down the road. It's a total of about two to three minutes.
After doing all that, I figure it should be warmed up enough.
If you are only riding one mile to work, you're probably not burning out the condensation. I can't imagine the oil getting that warm in just the time to ride a mile. That would probably qualify as "Severe Service"...I'd be changing the oil often.
