Jagg 10-row Oil Cooler Install on Ultra - Pics
I intentionally used the longest oil line to route the cooled oil back to the engine...figuring that as the oil passes through the line, it will enjoy additional cooling potential before entering the engine again.
Received 70,455 Likes
Thanks. I don't know what kind of temp drop I may see, but I'll have to wait until summer to see if it make a significant difference. Glad the Oil Bud is working well on your scoot there in SD. God knows it must get hot there in the summer.
Thanks for the detailed post.
I got the Jagg 751-FP2400 fan assist kit for Christmas. Little did the Bride know but I had picked up a Wards Parts Werks FCS cooling fan system from Jason (who is great to work with by the way).
The fan system is installed just waiting waiting on warmer weather to install the Jagg.
Ought to run a little cooler ya think !
Again, thanks !
o~\o
Again, thanks !
o~\o
I use a 35mm Nikon SLR for the photos. I am not a photographer by any stretch of the imagination. It's difficult to get the camera to auto focus on what I want to shoot sometimes. Glad to hear that the pics are a help.
Interesting..They changed the routing of the cooler lines with those beautiful fittings. I actually wrote Jagg when i first received my cooler (3 years ago) and was concerned about the routing. Previously the lines were routed (if you sitting on the bike) between the left frame rail and the oil cooler then up to the oil filter housing. With this, the lines were sitting very tight on the frame rail and i was concerned about rubbing through. Jagg stated that they have been running the lines that way for many years with no problems. Interesting they have changed the routing. Thanks for posting joe.
The two lines on the left is a different model heat exchanger core, its a double pass, the core in this thread is a single pass. They changed the routing because they changed the core, no other reason, the routing for the other core was not a problem, been running it since 07 without issue. The two pass core has greater cooling potential, that's why they use it with the fan assist system.
excellent, did not know that. Thanks for the info ..
edit: after reading the jagg site, joes oil cooler that he has installed is also a double pass cooler. .. The only thing i could see why they would route differently then is because of the fan?.. The voltage regulator has to sit higher just looking at the pictures..Maybe the line would rub on the metal bracket..That is my thinking..Again my fan assisted with the lines running on the frame rail has caused no issues and im sure it wont...again have been running for three years now ..i just thought they had changed the design of how they ran the lines .. I should have done more research before posting
Sorry joe for high jacking
