Fork oil weights....B,E,SE
Old 02-23-2014, 11:13 AM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
Default Fork oil weights....B,E,SE
Can someone confirm the weights for the HD fork oil. Is the following correct?
B type = 5 weight
E type = 10 weight
Screaming Eagle = 20 weight
I did a monotube install for a friend and it requires 5oz of 10 weight each leg. All I had on hand was the E type. Hope it's right.
Old 02-23-2014, 12:41 PM
Hi-perf old poop's Avatar
Hi-perf old poop
Hi-perf old poop is offline
HI, I did the mono tubes on my FLTRX and I had on hand was some spectro 15 wt . Called progressive and they told me the 15 wt would be fine and probalby not tell the differance.
Old 02-23-2014, 05:07 PM
gdoc89's Avatar
gdoc89
gdoc89 is offline
Oil for monotubes is for lubrication only. Weight does not matter.
Old 02-18-2015, 08:24 AM
kitt90's Avatar
kitt90
kitt90 is offline
Default oil wieghts are wrong
Originally Posted by sanman4ever
can someone confirm the weights for the hd fork oil. Is the following correct?
B type = 5 weight
e type = 10 weight
screaming eagle = 20 weight
i did a monotube install for a friend and it requires 5oz of 10 weight each leg. All i had on hand was the e type. Hope it's right.
type e is 5wt type b is 10 wt type se is 15 wt see other post on this
Old 09-22-2015, 06:02 PM
Kevlar57's Avatar
Kevlar57
Kevlar57 is offline
Stage I
If you did Progressive Monotube Cartridges, the weight of the oil is not important. It's only purpose is to keep the exterior of the cartridge clean and free from rust.
seanrsevern
Shovelhead
07-05-2017 10:08 PM
Norms 427
09-17-2014 08:18 PM
badbs101
06-07-2010 12:26 PM
Patch
03-03-2006 09:30 PM
HDF Tech
08-24-2005 11:58 AM
Quick Reply: Fork oil weights....B,E,SE
