Lifter and pushrod question
Putting in 110 kit. Have about all done. Need to adjust pushrods. But engine is dry. I have put oil in crankcase. Will the pump prime the lifters back up if I turn the rear wheel a few times in gear by hand or do I need to take lifters back out and pump them full of oil by hand. Thanks
The spring inside the lifter will keep the plunger to the top. It is weak, but if careful you can adjust them as normal. Won't have to wait for them to bleed off. Once adjusted you can pull the plugs and spin the motor with the starter and pre lube everything and semi pump the lifters up. Why are the lifters dry? New lifters come with oil in them and the ones from the engine unless you took them apart will have oil in them.
I rebuilt the engine. New lifters. I installed the pushrods and adjusted. I didn't feel like I had the resistance I usually have when the lifter is pumped up. So I removed the rods and spun tire about ten times and reinstalled rods. Before I do any cranking I was just concerned if spinning the tire would pump them up or not.
If not I will just pull them out and be sure.
Salmo pass
Engine Mechanical Topics
03-04-2019 03:17 PM
