Need Brake Pad Recommendation
I have bought the factory pads and gotten the ebay pads at 1/3 the cost and haven't seen any difference in braking or rotor wear.
Organic/Kevlar pads - easier on rotors, cheaper cost, wear faster, but usually slightly longer braking distances and less linear response
Metallic/Sintered - metal powder compressed into a solid, better quality metallic pads will contain lots of copper, better heat resistance, best braking performance, longer pad life but increased rotor wear although it is impossible to wear out the rotors on a motorcycle during it's lifetime, with the exception of warping from excessive heat from over use, consistent from wet to dry performance but more expensive.
Good brake pads have a consistent feel when braking - more lever pressure generates a corresponding increase in braking force making braking modulation easier for the rider and producing quicker stopping distances. Cheap pads are suddenly grabby at high application levels and easier to lock your front wheel with. Pads that are grabby will produce longer stopping distances with a practiced rider because they will be more cautious in heavy brake application with them. Any pad will apply enough force to lock a wheel. Race pads are bad for street use because they are designed to operate at high temperatures and require pre heating to work effectively. Good if you are braking hard constantly but not so good for street riding for the same reason. They need to be hot to work properly.
Chances are your OEM pads are lower quality sintered/metalic pads. I would avoid, cheap organic/kevlar pads.
I've had good experience with the EBC Extreme Performance series pads.
I repeat, brakes (and tires) are not where you save your money.
