Küryakyn Fuel Door GPS/Accessory Mount #1691
I have a question for anyone that has the Küryakyn Fuel Door GPS/Accessory Mount #1691: if you don't always need the GPS mount, can you remove the thumb-screw and then remove the mount? Don't really need the mount when riding locally.
Looked through the installation instructions and watched a couple of their videos but don't see any reference to whether it can be removed when not needed. Logically, it seems like it would so you can easily remove the GPS when stopped for lunch or overnight.
I use this one. May not work on Faring bikes. Didn't see the Kuryakyn mount. Looks permanent
Garmin snaps in.
Run the wire in the Windshield bag and out to the handlebar mounted 12Volt Assy
Dump the whole shebang in the bag when I arrive or don't need it. no one has ever gone though my windshield bag. If I get paranoid I lock it in a bag
Garmin snaps in.
I emailed Küryakyn regarding their Fuel Door GPS/Accessory Mount #169 and got a reply back. Yes, the thumb-screw and mount can be removed.
I'd assure appreciate if someone could post a couple of pictures of it installed on their bike (or a link to somewhere posted on the Internet) with the thumb-screw and mount removed so I can see what's left. With the Bat-Wing, I'm thinking that the fuel door mount be the best and easiest to do.
Thank you.
Thank you.
Thank you.
Thank you.
Take a look at the other tech mounts they make, like here:
http://www.kuryakyn.com/products/423...nd-gps-devices
I use the one that mounts on the fairing using the existing bolt from the windshield.
I use it for my phone as its my GPS, Music, and because my job requires 24/7, I can see who is calling and decide if I want to stop and call them back. Doesnt take much to glance over and wont fully pull my eyes off the road.
They also make various mounts for GPS, Etc.
Also, when you say you used an existing bolt from the windshield to mount it, could you clarify that for me?
Thank you.
Checked out your link, and I see that the mount is available for either right or left side. Only shown with a phone, and I'm thinking a little bigger in overall size with a GPS. Which are you using and if it's a GPS, can you post a picture or two?
Thank you.
Thank you.
My fairing mounted mounts on the fairing using one of the bolts that holds the windshield in.
Mrs B would like your gps turned a little to the left, to improve her view of it, but it's a great location.
