Dyna beads not balancing wheels
I tried the dynabeads because I wanted to clean the wheels up and I was also having problems with the wheel weights coming off occasionally. So anyway I put the recommended 2oz. of beads in each wheel took off the weights and it vibrated terrible at around 60 mph on up. Tried an additional 1 1/2 in each wheel. Still vibrating bad. Question is do I try more beads? Ran smooth before taking weights off and trying beads. My wheels had a lot of weight on them but unfortunately I didn't look to see how much per wheel.
Since the source of the imbalance doesn't move, the counter-weight should not move either.
In other words, balance the wheel the way that the laws of physics dictate will work by removing the beads and sticking a weight on the side opposite the imbalance and equal to the mass of the imbalance.
I never had an issue with them. I can't see being more than 2oz out, but it's possible.
Removing them is a chore.... I don't think adding more would hurt, but I'm trying to figure out why you've got vibration.
Do you get a "mist" or "fog" out of the valvestem when you release a bit of air? I don't know if they are prone to "clumping" if wet or not.
If I ever get to the point where I don't have a tire/wheel warranty, I'm going to ride-right gel. Same concept as the beads, but with a sealing quality....
