Fuel mileage after Big Bore kit.
Old 06-30-2014, 08:41 AM
Jeff Vorhies's Avatar
Jeff Vorhies
Jeff Vorhies is offline
Default Fuel mileage after Big Bore kit.
I'm contemplating doing the S&S 98" big bore kit and S&S 510 cams in my 2003 Electra Glide Classic; I was wondering if anyone had done anything similar and if so, how much, if any, did your fuel mileage suffer?
Currently I have a 88" injected bike with Vance and Hines Dresser Duals, a Vance and Hines VO2 intake, Dynojet Power Vision tuner, and S&S 509 cams.
Just looking for others input before I go spending a bunch of money.
Old 06-30-2014, 09:05 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Do you have the wide band kit for that PV? If so, and you know how to use it, your mileage won't drop all that much while cruising.
Old 06-30-2014, 09:20 AM
Jeff Vorhies
I do have the Wideband kit.
Old 06-30-2014, 10:09 AM
mmats69's Avatar
mmats69
mmats69 is offline
I still get low to mid 40's
Old 06-30-2014, 10:17 AM
fwb35's Avatar
fwb35
fwb35 is offline
I would not put the 510's in, they are soft down low, something better would be the Andrews 37's in my opinion, really depends what you are doing with them, but for a heavy bagger either the Andrews 26 or with the big bore and higher compression the 37's.
I did the S&S 97 inch big bore, had SE204 cams until I went gear drive, I have a carb and am getting 34 to 36 mpg
Old 06-30-2014, 10:50 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I don't think any of us suffers with reduced fuel mileage when making engine mods, except when using the extra performance!
Old 06-30-2014, 12:26 PM
ZUTEDUFF's Avatar
ZUTEDUFF
ZUTEDUFF is offline
got BB, SE heads, S&S 570 Ezstart cams and gear drive....at 55 to 60...46 mpg.. after that it dropped to around 40-42
Old 06-30-2014, 02:18 PM
Kenney's Avatar
Kenney
Kenney is offline
I have the (TC 98" big bore kit 9.75:1 CR ,Andrews 37G cam, RP Hydro-Rev Lifters, HD Adj pushrods, CometicTop end Gasket set #1zx74w890352001874 , Basle Oil spring, Street Port on Heads) and the SE Tuner in my 2005 Ultra. I am running the Vance and Hines Dresser Duals and Ovals.
It was tuned to run on 89 octane as I can’t always find 91 on the road. I get (if I don’t start to play with it passing trucks) 36 to 40 mpg loaded and two up. At 2K RPM I have 100 TQ and Top out at 107 TQ and 97 HP. The TQ doesn't start to drop off till 4.5K RPM so I am always in the TQ band.
Old 06-30-2014, 02:31 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Hillside 98" Andrews 37- I'm getting 40-45, but I have a lighter bike.
Old 06-30-2014, 02:37 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
You are going to find that when properly done, and with an expert tune, mileage doesn't suffer much........... the problem is, with a performance build you will find that the problem will be with your right wrist. That will be where your fuel economy will go way down.
My 05 RG had a stage 4, and if I kept it on cruise control, I could get 44-48 on level roads and just flowing with traffic.
Take it off cruise and let my right hand control it, and I could watch my gas gauge go down, and my grin get bigger.
Quick Reply: Fuel mileage after Big Bore kit.
