Not enough oil
I'm at work and don't have the exact values in front of me. There are TWO different fill levels for the primary. One would be 'wet' fill' and the other would be 'dry fill'.
Wet fill would be the correct level used if all you did was drain the fluid.
Dry fill would be correct if you pulled primary chaincase cover, wiped it all out and installed new clutch frictions. The friction plates retain a LOT of oil, and there are various spots for oil to hide.
When I fill a chaincase for a fluid change, I put bike upright, look through derby cover hole, and make the oil touch the bottom of the clutch.
When I do a complete clutch change out... I use the recommended amount of oil, which at first looks overfilled, but once friction discs suck in some oil and get soaked, it eventually comes out fine.
Owners manual may only have the one level, but the service manual will list both levels.
