23" DNA Fat Spoke
23" DNA Fat Spoke
Looking to fit this wheel to my Road King, already got the wrap front fender and 7 deg trees waiting.
Has anybody had any problems fitting a tire to this rim (Avon or Metz)? I have heard one story about tire not sealing when fitting problem but want to know if it was a one off or should I just go ahead and buy?
Looking to fit this wheel to my Road King, already got the wrap front fender and 9 deg trees waiting.
Has anybody had any problems fitting a tire to this rim (Avon or Metz)? I have heard one story about tire fitting problem but want to know if it was a one off or should I just go ahead and buy?
Rim sealing is to prevent the leak thru the spoke. The inner tube removes all doubt. I had an issue a few months back with my rear wheel from DNA. It leaked and caused the tire to come apart while I was doing about 75 down the interstate. Yeah they fixed it...and I finally took the advice of everyone that gave it....run an inner tube. They're cheap...only about $20. Whats the logic to NOT running an inner tube...especially when they are so cheap???
I believe DNA have upgraded their wheels and now are fully sealed (spokes) but as u know when mounting a new tire it has to 'pop' when sealing correctly on the rim. I have been told the 21" is fine but for some reason the 23" is a problem, just trying to find out if others have had the same issue.
My mistake, got 7 deg triple trees and a progressive lowering kit
Good plan. Running 9* trees on a stock frame isn't a great idea, but either 6* or 7* trees, along with the 23 wheel, and your ride and handling will be just fine. (better still, if you add a little rake to the frame, though). The difference between the 6* and the 7* trees is mostly marketing.
