Need help on the road
It may be some slack in the primary chain when it's hot, the adjuster may not be adjusting correctly. Where in Colorado are you located? Mile high in Denver and Parker are great dealers if you want to get it checked out. If it is shifting ok the clutch may be ok. Does the primary make any strange noises on start up?
Compensator
I have never heard of the compensator making noise on loss of load. If anything it is when you are loading the engine when a compensator makes noise.
If you have any tools, I would pull the derby cover and see if you can reach in with a screwdriver and test primary chain tension.
