Suggestions on replacement batwing vertical brackets
I've already done a few crack repairs with kits on different parts of my 2009 bat wings internal vertical brackets over the years.
I noticed another crack starting last time I had the batwing off. I think this winter I'll just replace them.
I saw at one time some kind of replacement plastic abs brackets.
Can anyone recommend good replacement aftermarket brackets that have proven them selves?
Thanks
Thanks
Yours should be the upgraded HD ones already as I believe they began using them in 09. If not, or even if they were, I would put in the upgraded HD ones. I would also try and figure out what caused yours to crack and fix the problem. I have different bars, 7.25 J&M speakers, an amp, tweeter pod, quite a bit of stuff on the fairing, etc. that adds up in weight and mine are still going strong and they are the older style. Those nylon ones may be strong and may work well, but I don't know much about them.
These must have been the "ABS" ones you saw. They are actually nylon.
Took a couple of hours but the next time will be quicker, now that we know what we're doing.
Going to replace my '07 Ultra supports when winter comes, even though the brackets are fine.
They do carry a life-time warranty.
Thanks as always for your feedback.
Just installed them on an '03 Ultra who had both support brackets and both speaker supports broken.
Thanks
Thanks
Dun Roamin
05-24-2014 10:14 AM
Kielbaso
02-05-2010 06:20 AM
