wheel bearing sizes
Old 09-05-2014, 03:04 PM
jdh1340's Avatar
jdh1340
jdh1340 is offline
Default wheel bearing sizes
Hi
got a 2008 FLHRSE4 CVO Roadking and would like to change the wheel bearings sometime
anyone no the sizes and part numbers for front and back,would rather not pay HD prices,want aftermarket ones?
Old 09-05-2014, 03:15 PM
Jumpman's Avatar
Jumpman
Jumpman is offline
2008 should have 25mm front/rear.
Peep this out.
This is the mobile link. Great site to bookmark.
http://partstream.arinet.com/Mobile/S_b0ZVJdlzZRG2n5i2wSxadRMj9VJDYLioow1x-RG-abFmEaytYDIvGwhNqgmxFvzPmlp46OmApaPASYmwyUP9hgY7mF hn1oDPt5nWORl3-E8ZK4TVvJ4RE26O-4iya60.html
Old 09-05-2014, 03:17 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
25mm front and rear is correct on all 2008 and newer touring models.
Old 09-05-2014, 04:48 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
2 of the bearings are 6205-2RS. The other 2 abs bearings are only available at Harley from what I've heard.
Old 09-05-2014, 04:53 PM
lp's Avatar
lp
lp is offline
Received 2,746 Likes on 1,559 Posts
And 6205-2RS is available at NAPA for 8 whole bucks. I use them. No problems...
Old 09-05-2014, 05:03 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
I will assume that the CVO Road King came with ABS so you will be stuck with Harley for the ABS bearings since no one else makes them.
And since you are in Ireland I'm sure that makes the Harley price even more painful.
Old 09-06-2014, 09:38 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
Originally Posted by jdh1340
Hi
If you have ABS you have no other choice than H-D, but if not, simply take one of your current bearings to any bearing supplier. The numbers engraved on it will enable them to give you direct equivilents. I did that many years ago for my shovel and they turned out to be identical to a Ford car's wheel bearings!
WP50
08-10-2021 07:42 PM
HubBub
12-03-2018 08:36 AM
In2It
06-19-2015 06:00 PM
jdh1340
Screamin Eagle CVO Models
09-05-2014 03:01 PM
bluey
01-09-2010 07:22 PM
Quick Reply: wheel bearing sizes
