Decat or aftermarket?
Whats the opinion on de-catting the factory header or going to aftermarket head pipes on performance? Here's my situation, I've got a '15 FLTRXS that I put RCX mufflers on & I'm either going to de-cat or go with Rush HO duals or V&H power duals! I will most likely add an A/C & tuner to complete the stg 1! I can do the de-cat for all but free & pipes are going to run me just under $500! What do you all think is there a performance edge to the aftermarket pipes at this level!
Thanks
Troy
Thanks
Troy
I have decatted four of them so far by cutting a window and welding it back up, and all the bikes run well with a good tuner. It should only take about an hour after the pipe is off of the bike.
Having had the cat chamber open and digging that stuff out, I don't see how you could get it all out with a drill, but if people have done it and say it works, then I will not say it can't be done.
Fuel Moto has a dyno sheet that shows a stock '09 (no cat) vs. a stock '09 with a Jackpot header. No other mods. There is a 1.8 difference in HP between the two. So much for scavaging, big power gains, or losses.
As far as the o2 sensors go, those are not even hooked up if you use a PC-5 from Fuel Moto. Not sure about other tuners.
Maybe if I was going to do a lot of mods like cams, heads, etc. I might consider a head pipe, but for the standard slipons, aircleaner upgrade, a decatted headpipe is all that is needed.
Bill
Bill
Beary
Just getting the weight of a stock header off the bike is an improvement.
Once you have the H-D header off the bike and see it on your bench, you'll see what a kludge it is. Poor design, heavy, poor flow, definite hot spots evidenced by discoloration.
Jackpot header is the way.
I'm surprised no one in this thread had addressed the health risks of poking around inside a catalytic converter.
Received 2,524 Likes
