Handlebars and cables
I'm going to change my Ultra handlebars to something more comfortable (I hope) and I was told that I would need new cables 4" over.Now,will I have to get all the cables replaced and should I stay with the H-D ones or are there better aftermarket products?The handlebars I chose are the WO 575.Thanks for your help.
After trying different bars within the limits if stock cable length I found that I was better off buying a little more cable than I thought I would need. The difference between 4&6" isn't so much that you can't hide it if you don't need it.
Unless if course you have the money to toss at it, I tend to be cheap and only like to do things once.
I was amazed at the jump in quality between stock and Barnett cables, they were so much smoother (Barnett) operating and could be seen when side by side with stock.
I'm glad to hear that,it conflicts with what I was told by somebody from WO!Now,if you don't mind,could you tell me the reasons why you absolutely "LOVE" these bars.Thanks
I had the 575 on my 2010 limited. traded bike thats why I said had. The only cable I had to change was the clutch because I did not want to reroute it outside of the fairing. And I also loved them. I now have a 2014 Limited and put the WO578 very similar. the 575 did not fit the 2014's. By the way I used a +2 cable.
I don't care what anyone says, it can be done. I did it! The only thing I did was reroute the clutch cable inside the fairing. In the stock position, it loops around a bunch of wires and stuff and all you need to do is put it behind all that stuff, run it closer to the inner fairing and then back out the same hole. No problems at all. I am 5"11" and I wear a 34" sleeve length but the stock bars gave me a burning sensation right between my shoulder blades after about 30 minutes of riding. The WO 575s bring the bars up 2", back 2" and are 2" wider. For me, they put my hands and arms in a much more comfortable and natural position. No more burning. I bought my bike new 3 years ago and if I had it to do over again, I would have put these bars on immediately after purchase.
