Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe
Old 09-01-2014, 05:04 PM
daryl_db's Avatar
daryl_db
daryl_db is offline
Default Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe
Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe for sale. $315 shipped in the 48 states plus 3% fees. It has 1400 miles on it. Its setup for both 18mm and 12mm O2 sensors. I have decided to go with a 2-1 Dragos setup.
Attached Thumbnails Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe-20140901_153552.jpg   Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe-20140901_153604.jpg
Old 09-01-2014, 05:13 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
what are the (what appears to be) large holes in the outside of the headpipe?
did you have the 18mm bungs welded in or were they already on the headpipe when you bought it from FM?
Old 09-01-2014, 05:27 PM
daryl_db's Avatar
daryl_db
daryl_db is offline
It is setup for 18mm O2 sensors. They were used for Autotune.
Old 09-01-2014, 05:29 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by daryl_db
It is setup for 18mm O2 sensors. They were used them Autotune.
on the outside of the pipe?
Old 09-01-2014, 05:36 PM
daryl_db's Avatar
daryl_db
daryl_db is offline
They are afr ports that were installed by the dyno tuner.
Old 09-01-2014, 05:39 PM
ridedaddy's Avatar
ridedaddy
ridedaddy is offline
Old 09-01-2014, 05:41 PM
UltraNutZ's Avatar
UltraNutZ
ah ok. makes sense.
Old 09-01-2014, 10:51 PM
ridedaddy's Avatar
ridedaddy
Did the tuner not realize there were 18mm ports already there? Sorry just trying to understand how a second set of 18mm ports could be usefull? Shouldn't be a big deal since they are covered by the heat shields. Do the plugs for those bungs interfear with mounting the heat shields, do they stick off of the pipe far enough to contact the heat shields?
Old 09-01-2014, 10:55 PM
JpowSG12's Avatar
JpowSG12
JpowSG12 is offline
1st Gear
Package deal? If you could PM me Im a newer member so I cant PM
Old 09-02-2014, 08:32 AM
daryl_db's Avatar
daryl_db
daryl_db is offline
Since you are a new member it will not let me PM you. Please send me an email at db1454@gmail.com.
Thanks,
Daryl
Quick Reply: Jackpot 2/1/2 Steel Plasma Ceramic (SPC) Coated Head Pipe
