Shock Pressure-Up or Down?
Received 3,940 Likes
I have found the best way to get the best PSI in the rear shocks is to find a road with a rough section that I can make multiple passes on.
I pick an arbitrary PSI and make a pass over the rough spot. I then change the PSI 2 lbs and make another pass. I keep doing this, making the 2 lbs psi change (BOTH above and below my starting psi) until I find the "sweet spot".
It is helpful to know that, because of the shock valving, it may actually be "softer" at a higher PSI than a lower one...so I just take the time to run the entire possible range in 2 psi increments.
I weigh 190, Mary weighs 135.
The best ride for me (1-up) is around 21 lbs, with both of us (2-up) it is around 25 lbs.
