A Follow Up to my New Battery Install Fiasco!
What a Fiasco!! Some lessons learned for sure.
A week ago I purchased a new battery for my Tri Glide from a ebay supplier, it was delivered in 3 days, so I had a little bit of a wait before the re-install. No Problem! During the 3 day wait, I did some routine cleaning and maintenance, reread some posts here on the forum, hoping the reinstall would go smoother than the how the battery came out of it's home under the seat. All went well, put the new battery in the correct way, tightened up all connections, put on the seat, and tried to start her up. NOTHING! I can't believe this! Thinking that my new battery was not fully charged, I uncovered the seat, took off the battery cover, checked all the fuses, retightened all the connections, and put it on my buddies battery charger. Two more days pass.....new battery is fully charged! Put it all back together...still nothing! I can't #$%5#*8Yfuc#$ing believe this!
So my buddy is the type of person who loves to take things apart, he wants to attack my bike....could be the starter, or the relay in the handlebars, or the stator, or the battery is discharging....or any one of a number of wrong solutions.
I'm truly frustrated at this point, and have had enough of this at home fix it phase I started. Most of you know by now where this story is going....
I call a tow truck and have the bike towed to Performance Cycles. Joe the mechanic calls me the next day....biked is fixed!!
One and a half billable hours for $135.00, $60.00 towing charge, a new $120.00 Deka battery, at least 10 hours of my time, for a new
$4.29 key fob battery
Received 70,440 Likes
If your Trike doesn't have the alarm siren installed, put one on. That way if you are violating the alarm(bad fob) it will go off to warn you . Otherwise just watch the lights flash. If they do most likely the battery is ok..... Check for a reason.
When you turn the switch on, check that all switches are in the on position, your lights should be on. If they are the battery is most likely not the problem.
Just kinda basic............
Expensive lesson ! But one not forgotten !
Ride Safe!
Ride Safe!
