DK level kit installed tonight
Received 3,940 Likes
That sounds right for having the PSI pretty high in the rear shocks. Once you give it a ride and dial in your PSI for the most comfort, you may end up running a lower PSI and then the back of the bike might settle a bit lower.
I have not rode much since, just about 20 miles on them but yes, I can tell a world of difference. As far as leaking, I have not checked it. I am today going to fill it up to 30 PSI while it is just sitting in the garage and check it 24 hrs later and see what it is. I will let you know that outcome. But I can for sure tell a difference in turning, bumps in road are much much smother. Also adding a road zeppelin seat in a couple weeks that will help even more
cycler
11-11-2018 01:44 AM
armydgp
12-07-2017 06:56 AM
