Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Just ordered wards cooling fans
Old 03-02-2016, 12:41 PM
Slaw32's Avatar
Slaw32
Slaw32 is offline
Default Just ordered wards cooling fans
Jason was able to take my order for a set of his cooling fans yesterday . looking forward to installing them . I've heard that the high output 103 runs warmer than the 95 inch that was in my road King . any helpful hints on install or comments from those of you that run these fans will be appreciated .
Old 03-02-2016, 12:55 PM
bronxbill's Avatar
bronxbill
bronxbill is offline
Very simple install. Remove the nut holding the horn, slip the fans on reinstall the nut. You can wire directly to the battery; fans come with plenty of wire. If you are going to use the heat sensor, it is wired into the negative lead
Old 03-02-2016, 01:10 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,275 Likes on 11,144 Posts
Great upgrade...that I believe reduce my oil temp by about 25 to 30 degrees. When these fans are on I never go into EITMS. I wired them to the accessory switch, that way some Buffon can't turn the switch on when I am parked.
I also added the Jagg 10 row oil cooler with fan. That fan too is wired to the accessory switch.
Together with these I never exceed 260 oil temp. Used to go over 300, and the digital oil stick couldn't even measure the temp.
The Wards are one of my best upgrades.
Oh yeah, with the fans and the cowbell horn, there isnt much left on the stud. I recently bought the extended stud from Jason. It was a PITA to replace, but gave me a more secure attachment,
Old 03-02-2016, 03:16 PM
WRE4U's Avatar
WRE4U
WRE4U is offline
Thumbs up
they work great and actually look pretty good as well!!
Old 03-02-2016, 07:23 PM
paw paw willie's Avatar
paw paw willie
paw paw willie is offline
I've had them on 2 TG's and a FW. 97,000 miles total. EITMS has never kicked in.
Old 03-07-2016, 06:50 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,940 Likes on 2,295 Posts
What bronxbill said about the install. Super easy.
I have run these on 3 different bikes. They have worked very well for me. They were on my TG on my trip up to the arctic circle, including all the calcium chloride filled roads in the Yukon, the freezing rain, the snow and 110* temps. They just keep working.
Had over 50K miles on one set when I sold the bike. Of the two I have now, one has about 25K miles on it and the other about 30K miles on it.
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 03-07-2016, 07:20 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
WARDSPARTSWERKS is offline
The install is pretty easy, but there is also a set of spacers that goes in between the horn bracket and the intermediate bracket.
When the thermal switch is used the fans cant be turned on by someone walking by, and wiring to the AUX circuit will not allow the fans to run the cool down cycle after the engine is shut off; without the cool down the fans will heat sink with the engine and the excess heat exposure may reduce service life.
Old 03-08-2016, 08:34 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Jason..
Don't mean to hijack this thread
Wouldn't be caught dead without your fans. Even with that HUGE horn I have, making a bracket for it was real easy.
But...
I had to move my sensor to the right side rear head fin to stop short cycle. I haven't seen an update for a short cycle issue so am not sure if I have an isolated case. Have others spoken to you about moving the sensor?
Old 03-08-2016, 08:51 AM
Smokey Stover's Avatar
Smokey Stover
Smokey Stover is offline
Hey Wiz, Those finned head bolt covers block a lot of the flow through, They'll work much better w/o them.
Oh, And there is a new snap switch thermostat that works much better than the originals.
Mr. Wizard (03-08-2016)
Old 03-08-2016, 09:01 AM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Yes sir... agree 100%
I bought the bike used and they were on it. I gave it a good try to remove but either epoxy or red locktite was used on the threads and I don't want to break anything. Have done everything from just a long lever to heating up the threads... nada. Won't budge.
Sometimes it's best to leave well enough alone.
Have been out of the loop with Jason's product. Didn't know about the new stat. Mine works great being on the right side... no trouble at all. Was just wondering if I was an isolated case.
Thanks for the heads up.
Quick Reply: Just ordered wards cooling fans
