Is there a SERT available for the 2014 and up trikes? All the ones I have seen in the HD site stop at 2013. Could it be that the interface is already built into Rushmore?
If there is would anyone have the p/n?
Appreciate the help.
The same PN 32109-08C is for 02 and later touring and trikes. You also need cable kit PN 41000018 which is for the 14 and later touring and trikes. FWIW there are a whole lot better tuning products out there, what is pushing you towards the SEPST?
Only because I have those tuners on my other bikes and have the software on my computer. Did they change the connection on the bike for '14 and up so that you can't use the same cable that connects to the bike?
I would be interested in your take on what other tuner options are out there for the 103HO, I know you have a lot of experience . I've read through many of your posts.
Thanks for your input...
Yes they did change the cables, you'd be looking for cable kit PN 41000018 for the SEPST. I'd also look at the TTS, I've been using one since when HD had them as the SERT. The TTS just seems to do what I need, so I've stuck with it. Another one to consider is the Powervison, if you choose the vision, get it from Fuelmoto for the technical support they offer.
