Road zeppelin
We've got a year on a used 3-button; all the chambers hold but the compressor keeps cycling, probably a bad pressure switch or something. But I knew that when I got it. I just put it on a switch; you only need power when you're pumping one of the chambers up. Not worth sending it in to get it fixed
Change the pressures around every half hour or so and you can remain comfortable quite a bit longer than without it. True on the seam holding a bit of moisture, but the comfort of the cupped shape makes up for that. Get a cover.
