Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Back rests
Old 02-24-2017, 01:16 PM
laabdog's Avatar
laabdog
laabdog is offline
Default Back rests
I see Harley has two different back rests the standard that doesn't adjust and the adjustable one. Is it worth the extra money to buy the adjustable one that cost a lot more money over the standard fixed one. Also when they say adjustable is that just up and down.
Thank you
Old 02-24-2017, 01:40 PM
crabio's Avatar
crabio
crabio is offline
I think they are referring to adjustable being moving forward and backward. Not sure. Could be wrong.
I have the non adjustable one and it has slots that allow me to raise and lower mine.
I didn't think I'd need the adjustable one cause once I get it set where I like it, I'd never move it again.
I was able to adjust the angle on mine by adding a couple or three washers to the front mounting hole. Boom. Adjusted
Francois.j (02-27-2017)
Old 02-24-2017, 02:50 PM
bagger51's Avatar
bagger51
bagger51 is offline
I have the adjustable. It can be very comfortable, although it is hard to adjust while riding unless you have very long arms.
Old 02-24-2017, 02:56 PM
TH6161's Avatar
TH6161
TH6161 is offline
I had an adjustable one for 7 years and never moved it. Just got my 2017 and got the one that doesn't adjust. I thought the adjustable one just pushed you up a little is all it did for me. There is a lot of adjustment to be made to the cheaper one.
Old 02-24-2017, 02:58 PM
470004's Avatar
470004
470004 is offline
Received 15,053 Likes on 6,220 Posts
I have the adjustable one on my TG. The non adjustable did not fit my TG as per the 2013 HD's Parts & Accessories catalog????????????????????
Old 02-24-2017, 03:18 PM
laabdog's Avatar
laabdog
laabdog is offline
Just our luck tri glide fits expensive one thank you all
Old 02-24-2017, 05:59 PM
LS Bob's Avatar
LS Bob
LS Bob is offline
HD says the non-adjustable doesn't fit. I bought mine for my 09 Road King, had it on my 11 Street Glide, and it went right on my 16 Trike. No problem.
Old 02-24-2017, 06:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is online now
I've used the adjustable for years. it is easy to move on the fly, i change it often to avoid getting stiff. it move forward and back on the fly, up and down can be done but not easy unless u get off the bike.
Old 02-24-2017, 09:29 PM
Bowler Jerry's Avatar
Bowler Jerry
Bowler Jerry is offline
I have the non adjustable one on Freewheeler 2016 catalog said so not fit trikes but 2017 catalog says it does. I didn't have any problem installing.
Old 02-24-2017, 09:39 PM
Casper's Avatar
Casper
Casper is offline
I've had both, I liked the ease of removable of the backrest on the adjustable one, but really the fixed one works just as well and a lot cheaper..
Also the fixed one got my 16 TG just fine
Quick Reply: Back rests
