Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Cams
Old 02-19-2010, 08:31 AM
timeout's Avatar
timeout
timeout is offline
Default Cams
ANY idea on which size cam for my triglide 09??
Old 02-19-2010, 09:02 AM
1plumr1's Avatar
1plumr1
1plumr1 is offline
SE 255 is what I put in my wife's. Huge difference on take off and bottom end torque.
Old 02-19-2010, 09:12 AM
hd74inca's Avatar
hd74inca
hd74inca is offline
Default Se 255
1plumr1,
hello, wondering what that 255 does at cruising speeds, raise or lower the RPMs?
david
socal
Old 02-19-2010, 09:19 AM
1plumr1's Avatar
1plumr1
1plumr1 is offline
Given the inaccuracy of the HD tach and spacing on the face, that's a tough one to answer. Not been on a dyno. I only rode it a couple times after the install, really didn't notice a difference at hwy speed as far as rpm, maybe 1-2 hundred. The wife says she doesn't notice any difference, go figure.
Old 02-19-2010, 10:14 AM
TOMCENTRAL's Avatar
TOMCENTRAL
TOMCENTRAL is offline
Cycle Rama 575 cams.Regards,Tom
Old 02-19-2010, 10:42 AM
TheJimer's Avatar
TheJimer
TheJimer is offline
I just purchased a Wood TW6-6 Cam for my ’09 TG and plan on installing it next week. Hopefully I’ll have some positive performance results to report at that time!
After much comparison to other cams and long deliberation, I finally decided on the TW6-6 because of:
v Impressive low end torque
v Impressive performance graph when compared to the stock cam
v Bolt in with no head work required
v Reuse stock springs
v Detonation concerns with other cams because I only have 91 octane in my area
With any luck all of my homework will pay off and I will be impressed with the results!
Old 02-19-2010, 11:00 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Originally Posted by hd74inca
1plumr1,
david
socal
I don't think cams will make any difference.
Old 02-19-2010, 12:01 PM
grimm's Avatar
grimm
grimm is offline
if you are going with new cams, you may as well get rid of the chain tensioners and put in a gear drive kit, too. Less maintenance than the chains. i went with an S&S gear drive kit on my ride.
regarding cams, the type of performance you are looking for will dictate which cam you choose. if you want high speed touring and passing power, the choice will be different than if you were looking for off the line power and low end grunt. Jimer made an excellent choice with his Woods cams. me? i installed Andrews H55 cams. The power difference is huge. When i put in the power commander and dialed it in, the performance improved even more. good luck with whatever you choose.
grimm
Attached Thumbnails Cams-9730_1131142565103_1423422492_30318150_5274211_n.jpg
Old 02-19-2010, 01:59 PM
jraven's Avatar
jraven
jraven is offline
Harley just came out with a kit. screamin eagle pro 103 performace kit se259e cams, 10.5:1 pisons ect. Just had it installed, has a nice lope to it but haven't got any miles on it yet due to taking in for custom paint but will let ya know my thoughts once I get it back
Old 02-19-2010, 06:30 PM
oldmsocko's Avatar
oldmsocko
grimm
There is nothing wrong with the new set up HD came out with for chain tensioners IMHO. I haven't heard any negative reports on them.
Quick Reply: Cams
