Another Trailer Question
I'm looking for a trailer to haul an Ultra Classic and a Tri-Glide. We're planning on traveling south during the winter several times a year to escape the snow, cold and salt. So far, I've narrowed my choice to an aluminum, enclosed trailer with a 'V' nose for storage and mileage. Tow vehicle is a 2500 Ram diesel. My question is what size trailer?
That is exactly what I did. I have the wife's Tri Glide up front in the nose and my Electra Glide behind. You need 18'2" min inside length. I can tell you that combo will not fit in a 14' nose to tail. I ended up with a 16' box with a 3' nose. As I wanted to put mine and a buddies EG behind the wifes trike, I went with a 7'6 wide. That made the nose a little longer as well. It has 19'3 inside nose to tail. Three full length runs of E track gives you all kinds of options for tie downs. I use a quick detach wheel chock for the EG and it has to be removed to get the trike out of the trailer.
You will not have any problems with power and that rig. I have to use my Chevy 1500 with a 5.3 The trailer and bikes come in under the max allowed by the Chevy specs, but I upgraded the hitch and receiver to 10,000 lb units. I much rather have overkill in this area than fall short. Would like a bit more under the hood though. Hills and headwind will be a concern. You will have power to spare.
Though I would post a pic of my enclosed 7.5 X 16 inside. Just about finished up with the mods. Floor, hold downs, cabinet ect. We can get a trike and two full dressers inside. Trike in front and the Dressers side by side in back. Getting all the E track down and the floor cut to fit took more time that I expected. I am pretty happy with the results though.
