Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
will a bluetooth headset work on 2014
Old 05-22-2014, 02:27 PM
armydoc37's Avatar
armydoc37
armydoc37 is offline
Stage II
Default will a bluetooth headset work on 2014
hi I have a 2014 hd trike and was wondering since its Bluetooth will a Bluetooth headset work on it if so will it support 2 headsets? thanks
Old 05-23-2014, 12:29 AM
ELVISTO's Avatar
ELVISTO
ELVISTO is offline
Yes it will, look in the thin quick set up guide, very easy to do ,
Old 06-26-2014, 06:20 AM
Bucket list Trike's Avatar
Bucket list Trike
Bucket list Trike is offline
Default Harley infotainment music not compatable with SENA bluetooth
I purchased a Sena Bluetooth and after many tries I found the Sena will not play music on the headset. It will give you voice commands for the
GPS and you can receive phone calls but Sena sent me a email that Harley info will not play music over the Bluetooth headset.
Old 06-26-2014, 02:14 PM
screwball's Avatar
screwball
screwball is offline
We have the SENA SMH10 units. I purchased
Old 06-26-2014, 02:22 PM
screwball's Avatar
screwball
We have the Sena SMH10 units. I purchased a Clear Sound Bluetooth Stereo transmitter and a 7 pin to 3.5mm adapter. This will give you the music, PGS, and phone capability. I think the adapter was about $20 and the transmitter was $40. I chose the Clear Sound unit because you can charge it while using it, others wouldn't. I'll attach a picture with labels. If you want to kick it up a notch, you can order (About 30 bucks) the accessory helmet clamp. It allows you to use any ear buds or headset you want instead of the helmet speakers they provide. I took a pair of Sony Studio headsets, removed the head gear and put the earpieces in the helmet recess. TALK ABOUT GOD AWFUL SOUND!!! I can listen to Santana loud enough to make my eyes bleed and no one is bothered with my volume.
ENJOY.
Old 06-26-2014, 07:23 PM
MB1953's Avatar
MB1953
MB1953 is offline
Screwball, I am assuming that this is good for the rider (good for me), but would it also support the passenger? Since we ride 2 up, we are still looking for a comfortable solution to the factory headsets; we both wear HD half helmets, and for this it is a serious compromise.
Old 06-30-2014, 04:27 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
Are the factory headsets no good, uncomfortable? I have two I just got with my 12 and we both use half helmets! Haven't tried them yet. Did the trike come with two? Don't know if previous owner bought these from Harley or if they came with it new?
Old 06-30-2014, 06:54 PM
MB1953's Avatar
MB1953
MB1953 is offline
They are good, but our HD half helmets are just short enough that the earpieces have to be tucked partway into the helmet to keep them against your ears, which can get a little uncomfortable after a while. If they aren't held against your ears, the sound is weak.
The TG comes with one, but our salesman tossed the other one in; buying one is a $180 ticket. I am an engineer (and thrifty), so I haven't given up getting these to work. We like the half helmets and not ready to buy two new ones.
Old 06-30-2014, 07:26 PM
bikerbum's Avatar
bikerbum
bikerbum is offline
I bought a pair of 1/2 helmet headsets off the internet a couple of years ago. Googled up 7 pin Harley Davidson headsets and there they were. go around the neck and over the ears. The straps on our 'shortie' helmets hold the ear phones close to the ear. Wife and I are very happy with them. They run about $80.00 on line plus shipping.
Old 07-01-2014, 04:38 AM
ZBear's Avatar
ZBear
ZBear is offline
I need to examine both my helmets with head sets. I have new headsets in both helmets and this past weekend was the 1st opportunity to wear helmets during a PGR escort. My half helmet worked sporatically when I wiggled the connection at the gas tank. Switched to the full helmet. It worked sporatically when I wiggled the connection at the headset. Going to look at the pin connectors. Hate taking anything to the dealer.
Quick Reply: will a bluetooth headset work on 2014
