Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Cup holder
Old 06-02-2014, 04:01 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
Default Cup holder
Simple question! Just bought a 12 TG and would like to have a cup holder front and rear. It had one that Harley dealer sells, but the mounting bracket is wide so it was mounted down the bar, and hit the tank! Gone!!!!!
Any ideas, pics, would be appreciated.
Old 06-02-2014, 04:23 PM
iaff84's Avatar
iaff84
iaff84 is offline
I used the frame mount for me up front. It is now on shelf. You wear more than you drink. Then tried one on bars, same thing.
No help except what not to buy.
I am still checking around also.
Dennis Swan
Old 06-02-2014, 05:02 PM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
I'm searching for new cup holder also.....bought one from dealer, but won't stay stabilized. Anyone use loctite to keep screw from coming loose. Oh, would hate if that dropped on my tank! Water bottles come in different sizes and won't fit. Why is such a small item such a pain in the ****!
Old 06-02-2014, 07:10 PM
rick1201's Avatar
rick1201
rick1201 is offline
I am using the hog trough locking glove box covers with the cup holder.
hogtrough.com
Rick
Old 06-02-2014, 07:45 PM
TheBobs's Avatar
TheBobs
TheBobs is offline
hogtrough.com
Rick
+1 on hog troughs. I bought the double and have a water bottle on both sides.
Old 06-02-2014, 08:05 PM
Noble Jim's Avatar
Noble Jim
Noble Jim is offline
We use Kuryakyn front and rear. We like them.
Old 06-02-2014, 08:43 PM
rwhgme's Avatar
rwhgme
rwhgme is offline
Hog trough here
Old 06-02-2014, 08:53 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
Default homebrewed
Pipe clamp, metal, bolts, nuts and washers, 4" plastic pipe coupling, some pieces of an old leather belt and a few pop rivets. I had the paint. Six bucks, works great.
Old 06-02-2014, 09:03 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
I like your idea. But the issue is the mounting bracket! Having the reverse switch on the left leaves little room for a large clamp? I have a plastic cup holder I bought for my goldwing that would work perfect, but it is designed to use the clutch perch screws. But again the reverse blocks that. Will try to post pic tomorrow. Thanks guys!
Old 06-02-2014, 10:00 PM
Casper's Avatar
Casper
Casper is offline
Ok, this is my setup and have been using it for years, works great.
First. Get this for the driver
http://www.kuryakyn.com/products/756...-drink-holders
Kuryakyn also makes a mount that will mount behind the rear speaker pod on the right side for the passenger ( don't have link but easy search)
I use both the coffee mug and the ring will also accept a tapered 20oz cup from fast food or gas stations,
My main drinking mug is a Butler Mug from glass act, I'll post a link below.
http://www.glassact.com/
I mounted the Kury mount on the left handle bar, but using a little bit longer bolt for the Butler Ring I can mount the Butler ring and use the Kury chrome ring, also the rear Kury mount will accept the Butler Ring and mug....
The Butler Mug isn't the prettiest mug or cup holder, but it's by far the best! It'll keep drinks hot or cold for hours, just don't put a slushi in one, wife and I did and it froze within 10 minutes, keeps cold like I said.
Quick Reply: Cup holder
