V-Rod guys. Talk to me honestly
Also... V-Rods can be set up quite nicely for long distance touring. There are floorboard kits, passenger folding floorboard kits, fairing options, backrest options, if you can think of it, it can be done...
Is your bike still available and can you send me pics
I am not arguing with you. You have your mind made up and clearly I must of "stepped in something" saying something that wasn't politically correct - I get that a lot. I just wanted to warn off folks that are prospective Vrod buyers not to buy someone else's silly bike with these fake "performance mods" ---why? Cause I did.
I was a victim of that myself when I bought a 2008 VRSCDXA 2nd hand. I ride motorcycles 100% -- don't own a car. I ride rain/shine and Winter/Summer all year. Anywhere I go is usually on the back of my VRod. After getting it I got caught in a downpour on the Interstate and my engine choked out. Water had collected in the bottom of the open airbox and got sucked into the filter where the level rose and then sloshed into my intake. Not a good feeling on a dark cold rainy night hear your engine choke out and have to pull over to get re-started. So folks that make this "mod" should probably at least know that since I brought my bike up to OEM specs in regard to the sealed airbox that this has been a problem solved! Performance mod? What a joke... how do you measure that level of performance when you are on the side of the road trying to re-start your engine! LOL
Also in cold weather I was getting rough starts and idle till the bike warmed up. Because of the open air box the intake air wasn't being directed over the intake air temp sensor and so the ECM was getting reading from the warm engine and not giving the engine a richer AFR when it was cold. Putting the air box cover fixed that too.
Also folks should know that the positive crankcase ventilator and oil separator that are in the airbox do not function without a sealed airbox because they operate off of intake vacuum. So at least know you are giving up some things.
I won't stoop to calling you names. I don't have to. I am not trying to convince you or anyone else -- just putting the information that I have come to know out there -- take it or leave it! If it were me I would want to know that I am getting a "Whole Bike" and not some kid's silly science experiment.
I do recognized a turned intake tract though. There is a reason the airbox is an air tight chamber and the air inlet trumpet extends out as far as it does. There is a reason why the rear velocity stack is taller than the front and not interchangeable. You can believe what you want of course but lets race in the rain sometime and I will show you where you are dead wrong.
CFR Title 40 -- Emission and Noise Control
BTW, the CFR regulation you quote isn't specific to this motorcycle or its design. It means nothing in terms of favoring this silly "topless" airbox mod.
The sealed airbox provides vacuum to the oil-separator and positive crankcase ventilation system which are considered to be part of the emission controls and that is the CFR 40 concern. The noise concerns only applies to muffling exhaust noise.
Anyway, I have rode with the air box cover off and the intake has a louder "restrictive air sucking noise" with the airbox on if you ask me. The rumor that the airbox was developed to lower noise is a total myth.
No Riding in the Rain
You lose the oil-separator and positive crankcase ventilator too... Ok for you but not a mod I like. My bike came like that and after getting choked out in the rain I went to the H-D dealer and ordered a replacement air-box, retaining clips, and rubber-seal. Problem solved!
I mean... really... why make the mod if it has these kinds of negatives. I think the designers knew what they were doing in all things on this bike (except fuel level sensor). I wouldn't buy a new Ferrari and drill holes in the intake tract claiming I am doing it for "'mo betta performance!" But I guess folks do...
